Ok...my curiosity has been sufficiently piqued to look into
Russian tube variants. Anyone point me to a comprehensive croos match so I know what the heck I'm looking at? I think some I am checking out are 6H9C...a supposed 6SL7 cross. I have seen some Russian tubes being sold on Feebay that purport to be close, but with a different pinout...not sure I want to go into that unless it's for a new project. Any help....yadda yadda...😱
I have a fairly extensive pdf I can send you.
I must admit that I am mostly in the dark about Russian tube numbers. Please email me a copy of your list.
If you want to make it public, I can put it on my web site if you want.
I have found out that many of those Ebay ads that claim to be "close" "similar" or "equivalent" are pure BS. Some don't even have the same number of pins.
I got some EL84 "equivalents" that have glowing screen grids in a Simple P-P. I got some other tubes from a different Ebay seller that have the same Cyrillic number on them that work well in the same amp. We have all seen all sorts of tubes sold as 6L6GC's too. Some can take serious abuse, some will melt!
Dear DHT112A
I am as well very interested in your list with russian tubes. I tried to email you through this site but unfortunately your email is locked. Please drop me an email and I will forward my email address to you.
Thank you very much in advance.
Karsten
Karsten
DHT112A said:I have a fairly extensive pdf I can send you. It's too large to load on this site
Send it me please; I may correct and add something (I am American with Russian design, engineering, manufacturing, tech support background).
Also very interested 🙂 Please email a copy.
I'm trying to send this pdf but it is 10.7megs and I can't get my mail to send it. Fortunately I am one who has not lost a job and have to go to work this morn. Will try to get it to someone who can post it on thier site this evening.
You could get a place on www.4shared.com ( free version). Give us the URL and we can all download from there.
Ok, here it is
http://www.4shared.com/file/108571968/fd70c4c9/Russ_tube_cross.html
Can't vouch for accuracy.
I bought one of those cheap push pull "6AQ5" Chinese amplifiers off Ebay.
I can't say I was real happy to find out that Russian and Chinese "6AQ5" have 9 pins.
Win W5JAG
Thanks for that guide, it should be interesting reading.
Page 4 of the guide lists 6P14 as equivalent to 6BQ5 and 6GK6.
6BQ5 and 6GK6 are pretty similar, but they have materially different pin outs.
Win W5JAG
Win W5JAG
That was the example that I remember. Don't fall for their "WE417A equivalent" either. I am glad to see that neither of these are listed in DHT112's book either. These "equivalents" are likely the work of an over ambitious Ebay seller.
DHT112, thanks it is a good reference to clear the confusion.
I wrote this article some time ago, published in an italian hi-fi magazine:
http://giaime.altervista.org/china.html
I hope you find it useful 😉
Ditto 6N3P, their advertised "equivalent" to 5670 / 2C51. Pinout is completely different.
That little Chinese amp also taught me that incompatibility the hard way.
Win W5JAG
Win W5JAG
I've thought about this a little, and it seems like it may not have been pinout, but some other physical incompatibility between all of the 5670's I own, and the 6N3P sockets in that little amp.
Win W5JAG
Many auction titles that mention "XYZ compatibles" were really meant to say that the tube on sale performs very similar to tube XYZ while not neccessarily having the same pinout. An example of such tube would be 6N2P, a replacement for 6.3V heater wired ECC83/12AX7. It is not fully compatible though (its heater is hardwired in parallel). Some other tubes not only differ in exact pinout but also have different basing (9-pin noval instead of 7-pin mini for example).
So do remember to always check the datasheet 😉
I had a quick look at the abovementioned PDF and it seems to be accurate for all russian tube types I could remember off the top of my head - it doesn't even list said "semi-compatibles" such as 6N2P/ECC83.
- Tubes / Valves
- Russian tube equivelants
