running without a speaker?
Some load never hurts the amp.
I prefer to use some kind of load as I can measure all the amp.
Make a 8 Ohm load using high power resistors.
I have my own dummy load, made from 2 blocks of 5 x 10Ohm/10W wired in series for 4 Ohm and 4 blocks for 8 Ohm.
For some reason, there is confusion about loading power amps. In theory, all solid state amps can run without a load. With tube amps, the output transformer apparently reflects the load in some way to the amp, and this can cause problems. IF you are still concerned, just put a 100 ohm 2W resistor or even more across the output. It won't get too hot, but it will potentially damp the output stage, if that were at all necessary.
