Rules for capacitors...
I am upgrading the caps in one of my projects and I have an 85vdc input and the caps I want to use (Wet Tantalum) are rated at 60vdc, if I use two caps in parallel I would add their capacitance together (C1+C2) but would that also mean that I could run up to 120vdc through them?
God bless...
Mark
It is simply physics. When putting them in parallel you increase the plate area but you still have the same voltage across each capacitor. When putting them in series, they will each handle part of the voltage but the plate area is decreased. If you think back to your AC theory course, I am sure you will remember. The rules are exactly opposite of the rules for resistors and inductors.
Here is a good site to help refresh your capacitor theory: http://www.oz.net/~coilgun/theory/capacitors.htm
Pay particular attention to the 3rd page "Multiple Capacitors".
jcx
2003-02-17 7:38 pm
tantlum caps are Not a audio "Upgrade"
it is a really stupid idea to series tantalum caps for more voltage
if the leakage and C ratio don't match exactly you will get unequal division of the voltage and with Tantalum caps the failure mechanism is to short circuit (at least until they catch fire due to power dissapation if the supply is stiff enough )
Do Not Use Tantalum caps where there is any possibility of exceeding their V rating
aside from the fact that Tantalum caps are highly distorting, mining tantalum has bad environmental and humanitarian consequences
modern low esr, long life Al electrolytics should meet any audio need
