Hi All,
maybe iancanada could help me - or anybody else here.
I'd like to build an all-in-one streamer (with 4TB 3.5" SATA->USB3 HDD within the same DIY case) for my father. For that I came somehow to Audiophonics.fr, a great DIY site where I cannot register due to the half-French language and even switching the forum engine to British English, I get "Saisissez une lettre sur 2 du nom de notre société" as a confirmation of registration. No online translators gave a reasonable translation for this so I don't know the exact question
- hence I have to ask here, on my favourite forum.
(I hope this is okay for moderators).
I'm interested in a good strong audiophile solution with the Raspberry Pi4/4G, I have some DAC board related questions:
1. Is the Iancanada ES9038Q2M double-mono DAC board compatible with Raspberry Pi 4 ? I would like to work with the new Pi4. I assume yes, it's compatible, but I better ask here.
2. Is the solution compatible with Volumio ? I would like to use the whole setup with Volumio. I read somewhere it's supported but I'm not 100% sure.
3. Can I start first without the Iancanada FiFoPi Ultimate board and just put it later below the double-mono DAC ? So at the beginning the Pi4 and the DAC board would be the only two components.
4. The Pi4 needs heatsink and I intend to put a huge one onto it (to remain passive) so attaching the FiFoPi (or any other hat) is not an option for me. Is there a cable (40-pin IDE cable maybe?) so I can make a breakout of GPIO ports ? The Pi4 could then get a big heatsink and I would connect FiFoPi+DAC combo with a short, good quality cable onto the Pi4's GPIO. What kind of cable would you recommend ?
5. Since I would like to build a HDD into the case as well, a general RPi4 compatible case is again not an option. Maybe I'm using a screen too. Is there a general back panel for the Pi4 and for the ES9038Q2M double mono board ? Either as 1 panel or 2 separate panels so I can put the Pi4 outputs and the DAC board's outputs to the back of the appliance.
5.2 Even thinking putting the whole into a nice thin-mini-ITX HTPC case. Again, the back panel question..
6. I would separate and shield noisy parts (HDD, HDD PSU, Pi4 PSU and the Pi4 itself) from the 'silent' parts inside the box (FiFoPi & DAC Hat). What kind of little-cute PSU boards would you recommend me for the 2 sides ? (AC is 230V/50Hz here and I bring it into the case, connected to a switch button. Several little PSU-s are okay too, if needed, I can make the wiring). I don't want to dismantle fully ready AC outlet versions (if needed I can do it of course, but it's a bit weirdo)
6.2 Alternatively, I would be even more happy to be able to power the whole appliance via 1 external USB Type-C (PD: Power Delivery capable) adapter and then make use of such an input inside, split it, modify it, filter it, whatever I need to feed pure silent DC to the most sensitive parts. A classic 230V cable is just too bulky but for now I have no complete USB-C solution in my head - but if you could help, that's an even better solution for me.
Many thanks for the answers.
