This is a Raspberry Pi based streamer that I built a while back.
I originally used it with a HifiBerry DAC+ Pro and later with a AMB Gamma2 DAC Module.
There is over $370 in parts here, I am asking $150+shipping.
You can use it as-is, or modify it to your liking.
Parts included here:
1) AMB sigma11 5V regulated PSU (for DAC module) (>$60)
2) Twisted Pear Audio Centaur 5V regulated PSU (for RPi) ($32)
3) Par-Metal 12"x8"x3" Chassis (~$65)
4) Front and rear panels by FPE. Rear panel is partially damaged near the left rear screw (>$120)
5) Schurter filtered IEC socket FN261-4-06 ($12)
6) Kimber FRCA RCA jacks ($30)
7) Raspberry Pi (~$35)
8) Antek 25VA 9V transformer ($18)
AMB gamma2 DAC not included but can be added for an additional $50.
For DAC you can use
- a RaspberryPi HaT module (such as HifiBerry, ALLO, etc) and wire to the RCA jacks,
- the AMB gamma2 module that I have (pictured in last photo). It uses a top of the line WM8741 but its downside is only 1.2V output. You can see it's spec here: The γ2 compact high performance DAC
- Lastly, you can use virtually any USB DAC, in which case one of the PSU's and the RCA jacks are a bit redundant. This unit was built more of an all-in-one.
For shipping, I'll have to check that tomorrow and I'll PM you.
