Hello,
I'm doing some research on ESL
And want to ask you:
What are de drawbacks of Round ESL's?
How small can a ESL (possibly round) be made And maintain a freq resp from 200 to 20k? (output doesn't have to be very high)
I hope you can help me
thank you in advance!
Kind regards
Kind regards
Annoying to fabricate. Annoying to mount. Susceptible to Bessel resonances.
That is a pity
but if I make the driver not round but lets say triangular😀
what would be the smallest where i could get a reasonable frequency resp?
Tnx
Tnx
triangular shape has been made at philips lab.
I've seen pictures of it. It is claimed to have a kind of distributed resonance. It is worth trying. However the maximum width (rule of thumb; max 100 times spacing distance) must not be exceeded so the width at the base is the maximum width.
I have never heard such esl, so it would be very interesting to report the results.
Regards, MartinJan
Regards, MartinJan
I don't think it would be difficult to make a round driver. If I recall correctly, the Malme patent was illustrated with a circular driver. The resonance probably becomes a non-issue when you put some diaphragm supports in the driver, as you will have to in order to keep the diaphragm from slamming into the stators.
For 200 Hz I think you could use a circle maybe 20-24" diameter. Insulators can be cut by using a router on an armature with one end fixed at the center of the circle.
Try it out and let us know how it works out...
I_F
I_F
It sounds very interesting and believable because if you make a triangle that does not have equal sides it could not have a base or resonant freqenty
and 2 of them fit in a parralellogram
so it looks like it is not so hard to build but maybe this kind of design will roll of lows?
I will look into it!
Greetings
Boy Griffioen
Greetings
Boy Griffioen
Yep, I am not sure the esl of the philips lab was a triangle, I think a parallelogram. (too long ago to remember)
Also, take a look at a picture of the new Final full range esl.
Smaller design
So round is possible but the 20" is a bit big for my purposes so can anyone tell me if it is possible to make it smaller and keep the low end intact? some decrease in dB's is not an issue to me If it can keep a steady 78 dB at one meter (in an anechoic room so reflections can not help) i'm more than happy
Greetings
Boy Griffioen
Greetings
Boy Griffioen
If you need Mylar (r), you can contact me (I'm in the Netherlands)
I am also able to provide you EC-coating which is the best you can get.
met vriendelijke groet, MartinJan
mj-dijkstra@zonnet.nl
- Planars & Exotics
- Round ESL
