The previous problem has been resolved (doing nothing). Now, no longer able to read the TOC, the laser remains in a "central" as you can see from this video:
http://www.repo.intilinux.com/rcd965bx/MOV01466.MPG
Previously, the laser power is positioned to read the TOC at the beginning :-(
Any ideas? CDM 4 / 19.
A multimeter.
Initially, the lens worked perfectly (it was in the right position to read the TOC). Then I adjusted the laser trimmer (VR302) and trimmer which indicates the height of the lens, but things have not changed. Then I realized that the lens power did not come back earlier but remained in the center position as shown in the video.
I have not noticed anything broken in the mechanism and I put everything perfectly. Maybe the magnet does not reach the correct voltage? :-(
THANKS
THANKS
- Digital Source
- Rotel RCD-965 BX problem
