Hi
If anyone has schematic for this amplifier, I'd appreciate if you could send it to me. PM me and I'll give an email address.
Breez, Rotel make use of the same amp configuration in different model amps, Im not familiar with the 976 but I suspect its the single differential input configuration. In that case you could try get hold of RA01 schematic which would be very similar. Your amp is a 6 channel one if I remember correctly. I have RA01 it if it can help, what is the problem you having??? If I remember correctly someone has posted a circuit diagram of the amp section here somewhere, search for posts by member called Stee. If the problem is with the preamp section Im afraid it wont help.
This time I got by just replacing fuses, but a schema would still be useful for future reference. I'll try to look up other rotel models!
