I Have been careless with a speaker wire and The Left hand channel gone.
Can anyone please advise
1. Do i need to replace a fuse inside.
2. How please do I get inside . I tried gently with a screw driver and the screws round the side Black casing are to tight i do not want to knacker the heads. Or do you go in through the base of the unit. What tool is needed.
Second thing The Headphone socket dose not cut out the speakers when a headphones inserted i is this easy remedied once inside.
You need a service manual or, at the very least, a schematic diagram.
Those screws will come out if you have a screwdriver that fits. Press inward and only exert slight rotational force to avoid slipping out of the slot. Stand the receiver on its side so you can bear down with your weight on the screw head. I can give more details; I am a past master at removing difficult screws.
As for the headphone concern, many receivers were designed that way and you need to switch off the speakers if you want them quiet.
Thanks for the above nice thought Rotel Archive Owner's Manuals and CAD Drawings they got no info or manuals on my amp except the retail price when it was new
Was just thinking a long shot if there's any member In Bournemouth who look at it for me i be most appreciative
You can download all you need from B&W Group Service & Support Homepage
Thanks! I searched for the service manual for my RA-820AX for ages.
http://www.bwgroup-support.com/rotelservicemanuals.html thanks after another look look I did find the actual service sheet.. Lot of good its going to do me
cant even undo the screws Maybe that's not a bad thing as i have not got a soldering iron or be trusted with one.
Any hands on help would be gratefully received
- Rotel RA810 Amp
