🎄Rotel bridge rectifier replacement 🎄
Hi all, and a Merry Christmas🎄🎄
I'm looking to replace the bridge rectifier on a Rotel 920ax amp. Currently it's a pbp206, which is no longer made, and as I understand it needs to be improved upon in this amp, as Rotel's have a habit of eating their rectifier.
What would be a suitable option that can be relied upon in the long term.
(Have attached the service manual)
Thank you all in advance 👍
Seasons best wishes to all 🎄🎄🎄
It was a joke. An old-old joke. $7 semiconductors blow to protect $0.15 fuses.
(In this case the fuse is sized for the transformer. It is generally futile to 'protect' semiconductors with fuses, even moderately haft junctions like rectifiers.)
Yet this rectifier has died. In the 1970s I would spend an hour computing stray resistance on the rectifier time-curve. Today I just double or triple the rating of the failed part. (If I don't know which spec failed, voltage or current, I'd go up on both. This circuit "needs" 116PIV, and 3X is 400V, but 600V and 1000V are the same price. On test-bench this amp might suck 2.2 Amps, so 2A was cutting it very fine, so I would want to triple, say >6.6A. Rayma is pointing at very affordable 8A parts.
600 and 1000 volt versions drop a couple tenths of a volt more.
I only use three sizes of full wave block rectifier. 10 amp, 35 amp, and 50 amp. 10 amp in the SIP for all low to moderate power, 35 amp square metal case with the 1/4” fastons for almost all power amps, and the bigger 50’s when I really really really need it. 600 volt unless I get a special deal on the 1000’s.
Simple thumb rule, put the next higher rated, easier available part rated at least double the maximum rating, that means, if the amp is pulling 3.5 amps, you need 7 on the device, not available...so 8 or 10, whichever is sold in larger quantities.
600V is enough on a 110V or even 220V line, 1000 is over kill, but sometimes it is the part that sells more.
And do use the better quality ones, labor is more expensive than the parts, even your own effort costs time at least.
Do it once, do it right.
