Rotary stand (inspired by Joseph Crowe) with adjustable 3D printed feet
Joined 2008
I built a rotary stand that is based on the plans shared for free on TJC's website for outdoor measurements. I yet have to make the angle scale. Using the hinge seems to me as a great idea, it works perfectly.
I designed adjustable feet that can be 3D printed, each using two M6 nuts and one bolt.
After printing, insert the nuts and bolt as you see in the pictures. If too loose, use CA glue. Then, fix the base with three wood screws. After that, glue on the nut cover and screw in the foot.
STL files will be in the next post.
Reactions: stv
