I have used these in the past , never had a problem
[/LIST]
Thanks for that! I might upgrade in the future. For now, my selector switch seems to work fine. No funny noises when switching!
I have created a new thread in order to get help with the troubleshooting. You can find that here:
http://www.diyaudio.com/forums/chip...eshooting-help-needed-newbie.html#post2843306
Thanks for all your help so far, helped a lot!
Commercial Input Selector Unit with ELMA 04 Rotary Switch wanted
There are many key words for such a thing.
Input Extender - Stereo Input Control Box - Input Switching Control - Source Selector - Input Expander - Line Selector - Audio System Selector - Input Channel Switcher - Source Expander - High-Level Switch or Input Audio Control are some examples.
Therefore it is hard, to find an overview for such devices.
Here you will find such a line up (partly the naming in German):
HQ (3-Way Stereo Input Control Box)
https://www.amazon.de/HQ-ASWITCH-3-3-Fach-Stereo-eingangsschalter/dp/B000I8OOS8
https://www.tonecontrol.eu/hq-audio-input-selector-3w-(aswitch-3)-
http://www.ebay.de/sch/i.html?_odkw...C0.H0.XHQ+3+fach.TRS0&_nkw=HQ+3+fach&_sacat=0
Technolink Enterprise TC-64 and TC-781 Multiple stereo input selector (input Extender)
http://php2.twinner.com.tw/site/pro...ompany_SN=2280&Product_Site_Classify_SN=48734
TECHNOLINK ENTERPRISE CO. ???????? - Audio amplifiers, phono preamp, Audio Mixer, A/V switcher, Phono accessories, Integrated Stereo Amplifier, Controllers, Audio controller, Speaker controller, Audio control, vedio control, Speaker v (TC781)
T-Preamp TCC TC754 - 3 inputs preamp with MM phono stage - [English]
B-Tech BT-31 (3-Wege-Audio-Eingangssteuerung/3 Port Cinch-Audio Umschalter)
3-Way Audio Input Control | Products - B-Tech International
http://www.btechavmounts.com/file/bt31-spec-sheet-pdf
HiFinazory.cz • Zobrazit téma - 2 komponenty do 1 vstupu (signálový p?epína?) (Fotos)
SOUNDLAB/ELECTROVISION (4 WAY INPUT SELECTOR)
https://www.commsandsound.com/4-way-stereo-input-selector.html
https://www.amazon.de/SOUNDLAB-INPUT-SELECTOR-STEREO-SWITCHER/dp/B000KHDWXK
Profitec TC 6 Audio Umschaltpult
https://www.amazon.de/Profitec-TC-6-Audio-Umschaltpult/dp/B000NZM9F6
Dynavox AUX-S (Eingangserweiterung/Umschalter)
Dynavox: AUX-S Eingangs-Erweiterung/Umschalter
Collegare insieme molti apparecchi - come fare? - Vintage e dintorni Discussions on videohifi.com forum (Fotos)
Dodocus UBox6C/4C-D with Elma model 01
Dodocus – High-End-Umschalter fr Cinch Verbindungen
DODOCUS UBox6C Umschalter 6-fach Audio-NF Umschaltbox in Alu Natur / silber NEU
https://www.don-audio.com/Elma-Dreh...altwinkel-60?gclid=CMXt4sP_sNQCFXgW0wodq4cESg
Red Wine Audio Signature 3S (Source Select Switch)
https://web.archive.org/web/20070206191733/http://www.redwineaudio.com:80/Signature_3S.html
Goldpoint SW4 (Input/Output Switching Control)
http://www.goldpt.com/sw4.html
QED IX20 (Input Expander)
QED IX20 2 WAY INPUT EXPANDER | eBay
Conrad Audio Umschaltpult Order-Code: 350731 - 62 (only available in used condition)
https://web.archive.org/web/2013011...t-3-fach-3-x-Cinch-1-x-Cinch/1320012&ref=list
Bild: umschaltjmgs.jpg - abload.de
Luxman AS-4III (Line Selector)
https://www.camarossaudio.com/akses...-cable/luxman-as-4-iii-line-selector-nos.html
https://www.ebay.com/p/Hk94-com-Luxman-AS4III-Selector-Laksman-As-4iii/1039510503
Sony SB-900/SB-700 (Audio System Selector)
https://www.hifiengine.com/manual_library/sony/sb-900.shtml
https://www.hifiengine.com/manual_library/sony/sb-700.shtml
Reussenzehn Hochpegelswitch
Reußenzehn Hochpegel-Switches
manley skipjack® rca switcher (input channel switcher)
Manley SKIPJACK RCA Switcher
There are even a DIY (homebrew) version with ELMA 04 and RG316 coax cable:
http://forums.stevehoffman.tv/threads/know-of-a-great-sounding-analog-switch-box-rca-or-xlr.262857/
But I want to know such commercial devices, where the ELMA "04" is inside or the same rotary switch model under the brand name DACT.
Thank you very much for advices.
any news ?There are even a DIY (homebrew) version with ELMA 04 and RG316 coax cable:
Know of a GREAT sounding analog switch box? RCA or XLR? | Steve Hoffman Music Forums
Source Select Box equipped with ELMA "04" - cost-effectice Solution
AUDIOPHONICS Elma passive source selector 1 to 5 Silver
AUDIOPHONICS Elma passive source selector 1 to 5 Silver - Audiophonics
Parts for diy versions
Schalter
Schalter
Be careful of switching both signal and ground from a floating source. If the switch connects signal before ground, you are applying 120Vac at high impedance to the next stage. This is a sure way to destroy a digital volume control IC
What other versions equipped with ELMA 04 are there that are cheaper ?
Maybe this unit ?What other versions equipped with ELMA 04 are there that are cheaper ?
https://www.ebay.de/itm/29497119391...0221&toolid=10044&customid=349308261204965492
Which rotary switch is used here ?
This selector box isn't longer available - replacement are this box:Source Select Box equipped with ELMA "04" - cost-effectice Solution
Schalter
https://www.audiophonics.fr/fr/sele...4-vers-1-reversible-cablage-ptfe-p-13229.html
space is present to replace the rotary switch against a ELMA 04
This input selector unit equipped with ELMA 04 is only available in used condition:
Who know currently available units also equipped with ELMA 04 ?
- Design & Build
- Parts
- Rotary source selector for audio
