I am building an amp and like the symmetry of having the volume knob on one end of the amp, and hoping to use a rotary switch for turning the amp off and on, on the other end. I have no experience with rotary switches, and was curious if any 2 pole, 2 position switch with a proper voltage rating would be suitable to this application? I was also curious if there are any disadvantages or risks in using a rotary switch for mains power? Any help would be appreciated, thanks.
Nowadays you will be hard pushed to purchase switches like the old TV switches.
Plenty of industrial types; Rotary Switches | RS Components
A lot depends on the transformer you intend to switch. Large toroids can generate significant arcing as the contacts close and open.
You could always use a small switch to control a triac and so do it that way. Have a look at the PSU in Nelson Pass's A75 which does just that.
Both the lorlin and nkk switches look like they could work, I've come across a few other ones too that claim to be rated for mains voltage. I guess I'm curious if it would still be wise to take additional measures to protect the contacts from arcing, such as using a triac, or relay, and protecting the contacts with varistors. The pass a75 idea looks really solid, but i was just hoping to get away with something a bit simpler if possible. Thanks to everyone for the suggestions so far though.
The switch will be wired to a 9v 5va transformer powering a soft start circuit for a much larger 45v 800va transformer. Would a triac still be necessary in addition to the soft start?
If you already have a working circuit and just need to switch the low voltage AC side from a very small tranny then no triac is needed.
- Design & Build
- Parts
- Rotary off-on switch for mains power?
