Room correction with REW without a calibrated mic?
I ordered a UMIK-1 which should arrive in a couple of weeks. Meanwhile I'd like to experiment with REW, with a DCX2496 I got second hand.
As far as microphones go, I have an Audio Technica AT-2020 (XLR through a Zoom H4n Pro), and a Rode Podcaster (USB). Can I use these to experiment while the proper mic arrives or will it be a waste of time?
Can I hitch onto that? I have been in a discussion whether you'd want to use a USB mic like the miniDSP UMIK series or an analog mike with REW.
The reasoning was that the USB mike A/D and USB sampling/timing is not sync'ed with the D/A timing of the measurement signal sent out to the system under test via a soundcard.
If you would use a soundcard with an analog mic input, the signals to/from the PC would be sync'ed internally in the soundcard.
The thesis was that if the signals were unsync'ed as with the USB mike, the measurement would be inaccurate at some level.
Anyone can shed some light on this?
Jan
Yes, the main problem is getting the delay right between separate measurements. To explain this there is a workaround for USB mics that adds a timing reference signal. The additional reference speaker has to be held at a fixed distance from the mic between measurements.
here are the two extreme curves from ten small eletret mic capsules i tested
in this capsules case, if your working below 4-5KHz it should be resonable flat, above that response can vary
