hey all,
so i got a delay pedal and I know you can buy a footswitch to use the tap tempo function, but I'm sure they are pretty simple uinits to build.
However, I'm completely new to building audio electronics, so I wonder if anybody knows how to make one? All I know for sure is that it is an unlatching momentary foot switch...
any help will be greatly appreciated!
You've given us no information. What pedal is it, or do you have a circuit schematic? What kind of connector does the footswitch plug into the pedal with?
Hi mihir.
It sounds like a very simple approach will work. What you need is a momentary normally closed pushbutton switch, a little box or something to mount it in, and a cord and jack. Most likely 2-conductor. You should be able to just wire the switch to the two jack terminals. Polarity won't matter.
It might be a good idea, though, to use a resistor in series. Try around 4700 ohms to start: you shouldn't need to go lower than maybe 50 or 100 ohms.
Good luck!
Good luck!
