Rolling cap question
Joined 2009
Rolling different brands both of 10.000uF 63V caps in PSU I have to adjust the regulator because when one is adjusted to Vout 12V and change for the other brand the Vout is 11.90V, why this difference of voltage: is due to the fact of ESR so one cap have less resistance then the other?
And you are making a big thing out of a 0.8% difference.
I very very much doubt the circuit you are feeding from that supply notices any difference.
And maybe the difference is even smaller than 0.1V , simply your digital meter *must* choose between displaying 11.9 and 12.0
Actual difference might be a couple hundredths of a mV, simply one resides on one side of the threshold, the other voltage on the opposite one.
Joys of digitizing values.
I'm not worry about the difference it's just I'm curious why?
