Condition: used, in excellent condition and very low playback hours. New silicone damper has been installed by Ana Mighty Sound.
Tested in an IKEDA IT-407 tonearm with DIN 45549 test record.
Tracking ability: 120 micron / 315 Hz / lateral / 22mN.
Specifications:
Type : Moving coil
Output: 0.21 mV/cm/sec (RMS), 1.05 mV @ 5cm/sec recorded velocity
Stylus: Super fine line - F. Gyger II ( 6 x 40 micron ) nude diamond
Cantilever: Aluminium Tube
Tracking weight: 2.2 -2.5 (2.4 grams recommended)
Cartridge body: 5 axis machined solid aluminium alloy
Generator fixing: Unique 3- point rigid fixing, spiked to body (without adhesive)
Cartridge fixing : Standard 0.5 inch centres (12.7mm)
Recommended load: 30-1000Ω (100Ω recommended)
Coil impedance: 24Ω
Frequency response: 5Hz - 30kHz
Channel balance: Within 1dB
Channel separation: 0dB/ 1 kHz
F I M: < 0.5%, 19μ
Cartridge weight: 8.2 g
Asking price: EUR 1800 + shipping
Specifications:
Type : Moving coil
Coil impedance: 24Ω
F I M: < 0.5%, 19μ
