Thanks a lot!what version ?
newer versions uses this tweeter:
https://theartofsound.net/forum/showthread.php?24341-FS-Seas-prestige-range-tweeters
old versions - which I know uses a version with same mechanical sizes of diaphragm/dome (26mm) bot other material - same as to find on the H225 sometimes called "Supronyl" but I don't know the correct term therefore- go to
https://www.diyaudio.com/community/...as-k-19-f-h225-h-225-h0225-vifa-d19td.353654/
check also post #1.
greatest disadvantage of this old tweeter is the use of freeofluid.
Can be that you have info on tweeter that was originally fitted in Roksan Ojan 3? This is that what I really looking for.
(Asked about Roksan Darius just because they have similar tweeter with one from Roksan Ojan 3 if I am not wrong 🙂)
Who can upload the user manual of first version (images post #1) ?
And what other loudspeaker manufacturers uses this cage stand version ?
this URL don't provide the wanted information.
https://pinkfishmedia.net/forum/threads/roksan-darius-original-1980-90’s.217290/
I have the original Darius in cages with MK1 crossover dating from around 1986. I can provide a circuit diagram. It's a simple Single-Pole crossover and the speakers are very good. Revealing, stable image, require a good source.
Later incarnations of the crossover were apparently improved.
I'm in the process of activating them. Manfred Baier of Omtec built an active crossover for his own use - Bessel function, phase linear, 24 or 36dB slope I think - but I haven't been able to track down Manfred or his crossover.
If anyone has a later crossover @itsme5k, I'd be very interested in a circuit diagram or a closer look at it.
Next time I will post some information and images underThanks a lot!
https://www.diyaudio.com/community/threads/roksan-ojan-3-any-info.390256/
Concerning the used tweeter is the question, with or without Ferrofluid.
According the sound impression of a friend, who have purchase it in used condition, I guess without ferrofluid. Then the predecessors from one of this tweeters probably in use:
https://www.seas.no/index.php?optio...fw&catid=45:seas-prestige-tweeters&Itemid=239
https://www.seas.no/images/stories/prestige/pdfdatasheet/h1318_29tff_w_datasheet.pdf
or
https://www.seas.no/index.php?optio...dc&catid=45:seas-prestige-tweeters&Itemid=239
https://www.seas.no/images/stories/prestige/pdfdatasheet/h1149_27tdc_datasheet.pdf
found under this overview:
https://www.seas.no/index.php?option=com_content&view=category&id=45&Itemid=462
