I have a Rockville RX MD3 thats heating up the rail caps which leads me to believe there is a drive problem.
I have isolated the current draw to the audio section.
Does anyone have a diagram of the driverboard in the audio section as I am unfamiliar with this one. Is there any other amps that are similar to this one i can scavenge some posts or diagrams to get me started?
KTA1504 and equivalent I dont have in stock. Ive seen them replaced in the power section with MMBTA56 but not sure if these would work in the audio section.
It's essentially the same as the SLA1500. The driver board is a bit different with the 74HCT14 but should be fairly straightforward to troubleshoot, especially if you have clean drive coming off of the driver board.
Without the driver board, is there any current draw or DC offset on the output?
- General Interest
- Car Audio
- Rockville RX Md3
