Rockford T5002 help.
I have a burnt diode and some missing trace to repair. I started the process of repair but I could use a little help on where the trace should hook to the diode and go anyone have a good picture of this amps board and scheme.
You have the wrong model number for the amp.
http://www.vishay.com/docs/88587/es2.pdf
The code is ED.
See attached.
The code is ED.
See attached.
Connect only remote and ground and measure the voltage on pin 17 of the SG3526. Then connect B+ and confirm that the voltage increases on pin 17. Do this with no resistor in the B+ line and the 12v power supply set to about 12.5v.
The posted diagram shows the connections. I don't have a photo of this amp.
- General Interest
- Car Audio
- Rockford T500-2bd help.
