Rockford T1500-4 schematics / help
Hi guys,
Does someone has the schematics of the Rockford Fosgate T15004 amplifier?
The amplifier seems to have a slightly broken trace in the PCB which seems to be present in the filtering circuit. Only channel 1 seems to be affected by this problem.
The amplitude of the output sine wave on the speaker terminal is much lower then it should be. Pressing on the board (see attached photo) makes the output sine wave sometimes as it should be. Sometimes the music signal dissappears on the speaker terminal.
I cleaned all the switches and and resoldered the switches to make sure there is a good connection.
