Thanks!
The amp powers up, has good drive signal from power supply.
The amp has 78 vdc rail.
The amp is making regulated voltage.
I believe the power supply is functioning normal. The amp has no output and there is 2.7 vdc on the output terminals.
One of the gate drivers "UC3706DW" has 5.73 vdc on pin 2 the inverted input and the other driver does not. Is this voltage suppose to be there?
Something has the output stage completely shut down. There are no shorted drivers or outputs.
- General Interest
- Car Audio
- Rockford T10001bd
