Rockford Punch 360.6
This is a 6-channel amp.
I'm not getting audio out of the rear L and R channels after combing through several other faults out of this amp (Those faults have been fixed) not related to these channels.
There is no audio signal at any of the pins on XM3, but I do see audio for these channels on U5 OpAmp.
I played around with different input switch settings and still cannot get audio down to these channels. No signal on the IRFx540 so its not the terminals.
I'm going to pull the board back out of the sync later today. Any clues?
Thank you in advance
Pc # 1330F
I think I've found the issue. I was a bit mixed up with input RCAs, cards, and switches. This amp has about 10 or so combinations that make it a little confusing and overcomplicated. That and looking at it upside down from the manual while out of the sync didn't help.
I Read the user manual a bit more and seems all channels are actually working. Putting back into the sync to test some more.
