Do you have positive and negative supply voltage on U21?
Do you have rail voltage?
No hardly,
Pin 4: -1.055 vdc
Pin 8: 3.369 vdc
I have only 60 vdc across red and black wires which seems low to me.
Here is the pick. Pins 13 and 16 look identical. It seems the amp is only partially powering up. One set of regulators has output the other 2 sets have hardly any. 2 of the rectifiers have 60vdc the other 2 only have 20vdc. I am getting -9.50vdc on alot of the op-amps but only 1-3vdc on the positive side. Only half of the output fets are getting the -9.50vdc and the other half are getting no voltage.
This one has the revision done for the initial power up issue.
Pins 1 and 2 are soldered together and pin 13 has been removed.
pin 1: 1.776
pin 2: 1.776
pin 3: 13.65
pin 4: 0.095
pin 5: 1.381
pin 6: 4.41
pin 7: 4.70
pin 8: 0.785
pin 9: 0.785
pin10: 4.90
pin11: 8.31
pin12: 0.001
pin13: missing
pin14: 0.001
I posted a pic of the MOD the description of it was included with the copy of the schematic I sent you awhile back.
pin 1: 1.776
pin 2: 1.776
pin 3: 13.65
pin 4: 0.095
pin 5: 1.381
pin 6: 4.41
pin 7: 4.70
pin 8: 0.785
pin 9: 0.785
pin10: 4.90
pin11: 8.31
pin12: 0.001
pin13: missing
pin14: 0.001
- General Interest
- Car Audio
- Rockford Fosgate Type RF X6
