Rockford Fosgate T5002
I looked at the other 2 and all 4 were burnt in 2 pieces..
Left channel has very distorted output
Right channel has no output..
I replaced the resistors and they burnt up within 2 secs of power being applied..
So i guess i will have to take a look at what connects to them
If i lift Q2009 and Q2010 the resistors no longer burn in that channel..
With the Bias pots fully counter clockwise the amp powers up and idle's perfectly..
Bias pots are working correctly..
I have -0.70 volts measured directly across the speaker terminals for the right channel
