I got a rockford fosgate T20001bd in for repair. I have checked the powersupply fets and the audio outputs, these all test fine with diode check feature. The unit powers up fine, no protect light, and very little current draw. After applying a 100hz sine i expect to see some output but have none on ac or dc or very little to nothing on dc. there are no burns or blown components. I dont have a schematic so i cant tell where to see the carrier wave and my fluke 97 has complications moving from MO to NC this month. any help would be appreciated. Perry i didnt mean to post this in the rockford 801s. I was doing it from my phone when i was reading the post and hit reply ot post instead of start new thread.
Sounds like the problem is in the output if you are seeing little current draw. Try desoldering the rectifier diodes then test the supply for proper voltage, if you don't already have it with the output stage connected. Once that is ruled out, and if it is, I would suspect the driver board. These go frequently in car audio amps, usually due to heat build-up in the chassis. They are small and usually on a separate PCB standing on the mainboard somewhere. I will not be surprised if your issue is here. You could also try to trace the signal path from the RCA jack onward. Ignore the crossover controls for now if you can disable them. You may have a burnt a signal diode or resistor somewhere.
I have found some internal pictures of this model online and it looks like there is a small SMD op-amp based input stage you could check out quickly. Look for power supply voltage to the proper pins and if you have the means check for signal, if you know where to look. If there is a service manual or schematic be sure to find it, but you know that. I can't see well enough to tell you where the switching driver is, looks like it is near the fan in the center, to the far left, or to the right of the RCAs. So my guess is as good as any as far as that goes. It's probably by the fan, since it will have some ICs in it. You could look up the part numbers on some of the ICs and check for proper supply voltage and output if possible. This gets difficult quickly without a scope.
What's wrong with the scope? Is it something that you can repair (broken lead, dead battery) or do you mean that you don't have access to it?
To measure the rail voltage... Red probe on center leg of Q419 and black probe on 3rd leg of Q428.
Also confirm that you have ±regulated voltage on the op-amps.
Do you have all of the screws in the board in the power supply area?
There is a open cell in the battery pack. It has a power adapter but will not turn on. I am wondering if the power adapter charges battery and not run off the adapter.
It had rail voltage of 101 on all of the outputs for the center leg and leg 3.
I don't think that's possible since the center leg of half of the transistors connects to the 3rd leg of half of the transistors.
Confirm that the power supply for the scope has the rated output.
That's probably OK. Most AC adapters overshoot the rated voltage when unloaded.
And by a good margin at that
Q419&Q418 = 104vdc
Q428&Q428 = 2.6vdc
Q412&Q411 = 0.5vdc
Q405&Q404 = 100vdc
I replaced u303, u301, u301 and no change. I have chased the 100hz audio signal so far to u 300 pin 1.
Q428&Q428 = 2.6vdc
Q412&Q411 = 0.5vdc
Q405&Q404 = 100vdc
I'm not sure what to make from the numbers you posted. I asked for 2 specific transistors, which are not in the list. No need to re-post them.
Is the amp in protect mode?
Voltage on pins 5, 6 and 7 of U300?
Do you have audio on pin 5 of U300?
Sorry f or the confusion Perry, those were the 8 audio outputs . The numbers were the voltages from center leg to the far right leg.
U390 nEgative led on grd.
Pin
5= -4.94 dc
6= 1.538
7= 4.635
Pin 5 has no audio
Pin
5= -4.94 dc
6= 1.538
7= 4.635
Pin 5 has no audio
My confusion was due to the fact that you listed Q428 and Q428 together. You also listed Q404 and Q405 together and they're in parallel, not in series like the transistors I listed. It's not important other than for clarification.
I'm assuming U300 and not U390.
If those voltages are correct, that op-amp is very likely defective. Sometimes, op-amps will have an inverted output voltage (compared to the expected output) when the input is very close to the supply voltage. I don't know if this applies to this particular op-amp.
Perry...sorry auto correct is messing up texts.
I will replace it right now...give me one sec and I will let you know how it turns out.
Perry should I be taking reading with negative lead on -vac as ground or no when taking readings on pins 5, 6, and 7
-VAC? Did you mean -VCC? If so, please start proof-reading the posts.
There is no static positive or negative rail voltage in this amp. You use ground as the reference.
Did replacing the op-amp change anything?
- General Interest
- Car Audio
- Rockford Fosgate T20001BD
