Rockford fosgate T10001bd output stage damage
With the FETs in the circuit (and the PS drive shut down, as you said it was), post the DC voltage on all terminals of the SG3526. Copy and paste the following list and fill in the blanks.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Pin 17:
Pin 18:
Pin 1: 4.98
Pin 2: 1.8
Pin 3: 4.17
Pin 4: 4.72
Pin 5: 4.98
Pin 6: 0
Pin 7: 0
Pin 8: 0.156
Pin 9: 3.57
Pin 10: 2.133
Pin 11: 0
Pin 12: 5.0
Pin 13: 0.062
Pin 14: 8.11
Pin 15: 0.03
Pin 16: 0.066
Pin 17: 8.11
Pin 18 4.98
I mention that the voltage is being limited to 8.9v since if I increase it it will damage the lm6172, greetings.
Increase the 12v supply voltage while watching that voltage. Does it ever go above about 13v?
The regulated voltage should give you about 12v (as it is) but the ICs can withstand ±15v (30v across 4 and 8). Check the datasheet.
If something is damaging the IC it's not likely voltage if you don't see anything much over 12v.
I'm afraid they were damaged, I remember that when I repaired the track that I show in the photo, that's how it happened, it made the same sound and stopped listening and I no longer send a pulse to the output fets
