Rockford fosgate T10001bd output stage damage
Hi friends! I come back with another rockford fosgate T10001bd, they tell me that they hit the speaker cables and it started to generate smoke. When checking it I found this damaged ground track, I did a general check and nothing else marked me wrong and when I turn it on the current consumption is high and the output fets make noise. I disassembled them to check them and I found no damage to the output fets and transistors mpsa56 and 06, I measured signals in the ic drivers u202 and u204, but u204 is always sending pulses, but 202 is not, when placing audio both send pulses. It is normal? and I see that the ic of u200 (lm6172) and u203 (tl072) are different greetings and I appreciate your support
