Rockford Fosgate punch 500s
Ok so after I replaced a failed mmbt3904 the i/c is reading as such. The amp is powered up at least and not switching and the DC at the speaker output is .2mv on the left channel. And right is .8mv.
I found a falty mmbt3904 replaced them and have clear audio on the left channel. The right has since lost audio, I have not worked on that channel. Since I know the ic is functioning properly, and mosfets are good. It is a driver somewhere. I'll check later.
