Do Q403 and Q404 now match?
Basically, everything in the amplifier section from Q401 on determines the output voltage. Q401 and Q402 are only 'satisfied' when the voltage on their individual bases match. When they don't match, they drive the other components to correct for the error in voltage.
If you still have DC after replacing Q404, Lift Q405 and Q406. Does the DC go away?
Q403 and Q404 have been replaced and match, terminal still has DC.
Lifted Q405 and Q406 terminal still has DC but the IRF540 no longer gets hot.
The 540 isn't getting hot because the part of the circuit that compensates for errors has been disconnected.
What is the voltage, gate to source, on Q411 (black probe on the source and the red probe on the gate)?
No R452 is not getting hot but R430 is getting warm but not hot about 110 on the heat gun nothing seems to be getting extremely hot.
If you have 16v on the gate, you should see that same voltage across R452 (confirm). If you have 16v across a 560 ohm resistor, it should get too hot to touch within seconds. If it's not getting hot, it's either open or out of tolerance.
Post the DC voltage measured directly across R430, R431 and R432.
R452: -16.01 vdc
R430: -8.41 vdc
R431: 0.000 vdc
R432: -0.0012 vdc
The 560 ohm resisitor is not getting hot at all. Maybe I should change it?
R452 is likely open. Nearly 1/2w of dissipation in a 0805 resistor should create intense heat.
Remove Q408 after replacing it (and before applying power) and confirm that the voltage from the gate-source for the 9540 is 0v. Leave Q408 out of the circuit for now.
R452 was not open but not sure it was within tolerance. The resistor I removed read 555 ohm and the new one i put in read 561 ohm, quite a difference.
Q408 is removed.
Powered up amp and gate-source voltage on 9540 is 0.000vdc
Q405 and Q406 are still out of circuit. Should I put them back in or leave them out? Do these being out affect my readings I just gave you?
Confirm that you have 0v DC on the speaker terminals.
Is Q408 leaky?
Post the voltages on those three resistors again. They're all likely 0v.
What is the DC voltage on the solder pad for the base of Q408 (black probe on ground terminal)?
Is Q408 leaky?
Is Q408 leaky?
LR+ terminal reads: -0.015 vdc
R430: 0.000 vdc
R431: 0.000 vdc
R432: 0.000 vdc
Q408 base voltage 0.542 vdc
Q408 had lots of resistance in ohms so if its suppose to read OL in all configurations, then YES it was leaky.
Still wondering when or if I should put Q405 and Q406 back in?
I compared it to a new one and its virtually the same. The only way I get any resistance is red probe on base and black probe on collector or emitter. I get like 15.50 m ohms. On the old one same configuration I get 14.45 m ohms. I get OL in all other probe configurations.
So it must not be leaky?
Same reading as the A06 out -0.015 vdc
So there is a little voltage but just a tiny bit. I dont know why its still negative when its a positive terminal. I am holding the black probe on amp ground and the red probe on the LR+ (bridging) terminal.
That's a fraction of a volt and insignificant.
Isn't this significantly different than before you replaced the resistor?
Didn't you have full rail on the output with Q405/6 out and Q408 in?
More than significant I had over 29 vdc before.
Yes I did have full rail with 405/406 out and 408 in. So that little resistor being slightly out of tolerance caused all this, or am I not out of the clear yet?
The fact that it didn't get hot made me suspicious. R430 was dissipating half the power that R452 should have been dissipating so R452 should have been much hotter. I can't explain why it read as close as it did.
Replace Q405 and Q406 to see if the DC comes back.
- General Interest
- Car Audio
- Rockford Fosgate Punch 400a4
