Rockford fosgate prime r1200.1
Seems the amp has a couple blown gets and possibly other shorts. Haven't test all yet, just seen visual defects/burn on board. Seems fairly contained though. Transistors are irf3502 I believe that are toast. When amp is powered up the blue light is on like normal, just now output. Im kind of a newbie to amp repair but learning as I go... Anyone have a schematic for this amp by chance? Also anyone have a source for cheap quality replacement parts? Any help with this would be much appreciated.. Thanks!!
I don't have the diagram. Try Rockford but I think it's too new.
The driver transistors and gate resistors may be damaged.
Do NOT buy parts from eBay.
Mouser and digikey are user friendly and have first quality parts.
Did you check the output transistors to see if any failed. If they did, the repair may become far more difficult than replacing 4 FETs.
