Rockford fosgate 800a2 dc offset at both terminals
Hey guys I’m looking at this punch 800a2 board here the problem is there 54.14vdc at both channels. I was in the works of repairing one channel as you can tell by the picture. I installed some fets to test everything and so far it play clear and clean. Then both channels ended up dc voltage. Neither outputs appear to be shorted from left to right pins. All check out good. Any leads to what to check greatly appreciated! Thanks
