I cleaned all switches and pots in this amp checked solder connections all seem fine .
In the 100 series channel I cannot get it to play audio at all .
Any ideas ?
Any ideas ?
Did you or anyone else do any work on that channel?
Have you checked all of the output FETs?
How does the voltage across Rx22 compare in the two channels?
No one has worked on the amp .
R122 has 0.00 volts measured directly across it
R222 has 5.01 volts measured directly across it
All outputs test fine
- General Interest
- Car Audio
- Rockford Fosgate 500a2
