seems to be so.
i have measured somethings which i understand and im capable of. (not much tools)
mainly working areas i´ve touched, i need more time with this thing and need to measure few things which popped up my mind today.
i´m far from pro as you see
but yeah, really thought it was bad TO92 cause it measured so much different
To fix this amplifier you must be pro and with good knowledge at Rockford Fosgate products. this amplifier is sophisticated and not easy for who didn't work with this amplifier before.
if you have the schematic for this model and you understand the diagram i hope you will fix it. you have DC at the output terminal and i am not sure you are search the problem at the right place so far
Im really in dead end.
Q401, Q403 and Q404 are off board, DC is 0.4V, i think this is lowest number with this thing.
if i put Q403 and Q404 on board 42V kicks in, allways pair, dont know which one does it.
You said earlier check all transistors on board, measured (with my vbe matcher) and even changed few without result.
anything i can measure with multimeter?
im gonna take different approach. And explanation why i thought one TO92 was broken.
them factory Q408, 407, 406 and 405
there is one guy who looks different.
and my vbe matcher results.
one Q405, or MPSA06 pulls 3,49V voltage difference by its own
add second and its 16,6mV difference
Q408 or MPSA56 pulls 3,3V
add the different looking guy and its 1,138v difference, not good, right.
but thing is new MPSA56 i got can pull only 1,662V by it self
so new MPSA06 are 3,4V range. But paired withing 2mV
my transistor "matcher"
this is my tool, so is measuring vbe waste of time?
amp has now all parts in exept Q408 Q407 Q406 and Q405. dc rests pretty much dead zero
can i measure something from these empty holes?
just my thoughts
just my thoughts
did some measurements that Q405-408 has connections.
I dont know was it mistake to turn amp on without these four components cause all components are now on board and amp does not react turning bias pot any more.
Is it still check all transistors on board?
Haven´t heard that buzzing sound anymore and no wandering DC so some component is now really broken.
Gonna get some lunch and start to compare components between channels
factory Q424 Q425 Q404 Q403 on board and looks ok so far.
But if that different looking guy Q407 is on board i get -42v, it pass "universal meter transistor test" but if i change Q408 Q407 to new ones which i bought and leave Q406 Q405 factory i get 500mV DC.
i have feeling these four have to be similar.
Maybe i just have bunch of parts non interchangeable?
i still have to figure out why bias aint working
As my journey is this far im not gonna leave it to 16mV. (sure heat it up properly to see hot numbers later)Qx24 and Qx25.
What is your opinion now when all transistors are sort of pairs, am i gonna just take just little bit stronger transistor to Qx25 Qx24? and if looking to that another channels, those hot TO92's does it matter for effiency or something else if there aint good pairs? i have all eight allready choosen, just thinking if i take short or long course. Change them all and then Q324 Q325.
In factory i bet they havent choosen any components, just hit them in from same batch
- General Interest
- Car Audio
- Rockford Fosgate 250m2, badly beaten up
