rockford fosgate 1501bd
The rails switchers fail more often than the outputs. It could be that there is essentially twice the effective series resistance in the output current path than in the current path for the rail switchers.
I'd try a 2 ohm 100w (25 or 50w would work as well). You should have one for the power line when testing amps that may have problems. It wouldn't help much in the B+ line for this amp but it should work in the rail line. I recommend the tubular ceramic resistors, if you have to buy one.
