If y0u drive a strong signal into the amp, do you see a signal on the collectors of Q306 and Q307?
If yes, difference on level between the two collectors?
Sorry I mean collector has no wave. And the transistor is tested good I also changed it and no change.
With the black probe on the emitter, what's the DC voltage on the base of Q310? No signal and with signal.
Do you have -15v on one terminal of R317?
Is R317 within tolerance?
Emitter to base with signal 3.7vdc
Emitter to base without signal 1.45vdc
R317 has -19.3vdc. Resistor is good.
- General Interest
- Car Audio
- Rockford 800a2
