I have trouble with the left channel of my Rockford Fosgate 800a2 amp.
It began with noisy/distorted sounds from the loudspeaker at normal volume.
When I raise the volume up the distortion disapears.
It also stays away when I lower the volume.
When I turned the amp of for about one hour the problem becomes the same again.
First I thought that it was a bad connection to the speakers but now the distortion won't go away anymore, even if I raise the volume up.
I have also checked the gainpots.
Today I send a sine tone to the amp and check the speakerterminals with a oscope:
right channel:
Uploaded with ImageShack.us
left channel:
can anyone tell me whats wrong with this amp???
right channel:
left channel:
I have also checked this on every of the outlined mosfets with the same result, but always without load.
tomorrow I will check it with load connected. (I got the amp at work)
hehe
this is a good old RFT EO211 made in GDR
I think this scope is as old as me.
I checked the op-amps, u102, u104 and the a output (pin1) from u103 looks good.
but the b output (pin 7) from u103 got the problem.
does that mean that u103 is defective or is it something else?
Thank you for your help!!!!!!!!!!!!!!!!!!
haa!
I think I have found the problem!
I checked pin 5 and 6 (channel b input and inverted input)
they also got this problem.
So I traced it a little back and found out that c107 is the part where the damaged sine wave comes from!
between r199 and c107 the sine wave looks correct, but between c107 and c108 it looks damaged.
do you think that simply changing this cap will solve the problem or could there be anything else that cause this cap to fail?
damn, my fault...
The high pass crossover was set!
I can't remember that I have ever switched it...
At Full and Lowpass the Sine looks good.
here is a photo of R199:
As you can see, it is directly connected to C107 and Pin1 of U103
I have desoldered this capacitor:
you can see that it is broken!
Can you tell me what may cause this?
What replacement part should I use?
The capacitor is marked with 683.
683 = 68 * 10^3 = 68000pF = 68nF?
What does the color stands for?
The cap is cracked and you can see the pin inside of it.
And you can easily pull the pin out.
It also matches with my fault description, because in the summer (when it was warm outside
the problem disapears when the inputlevel/voltage gets higher.
Or am I wrong?
Should I pay attention to the rated voltage of the cap?
I have found this one: ECQE2683JF
Or am I wrong?
Sometimes, the epoxy can be cracked but there's nothing wrong with the cap. If the pin can be pulled out, it's definitely defective.
I don't know if this could be affected by temperature.
The voltage isn't important here. The lowest voltage mylar caps will be rated for 50v. The maximum voltage that can be applied in this circuit is 15v.
- General Interest
- Car Audio
- Rockford 800a2 problem with right channel
