This amp came in with a shorted toroid, vented C59 and vented C17.
I replaced all defective parts and upon power up the cap C59 immediately vents. C17 cap did not. It is installed correctly, I double checked.
I removed C59 again and checked the pads for voltage.
+ 13.57 on pos pad
- 0.957 on neg pad
The original cap for C59 was 100uf 25v. I installed a 100uf 50v and powered the amp and it did not vent.
I checked the pads with the cap installed and am getting +46vdc on the postive lead and the same reading on the negative lead as before.
This cap is tied directly to Q13 LM317 positive regulator. The in voltage on pin 3 of the regulator is obviously also 46vdc.
D6 and D8 also have the 46vdc on the cathode end.
I am confused as to where this 46vdc is coming from. It does explain why the 25v cap was venting, but not 100% sure how its getting there.
+ 13.57 on pos pad
- 0.957 on neg pad
I tested for audio before reading your post and it shorted U10. I replaced U10 and it shorted again powering up. So U10 is removed and I also removed Q108, Q109, Q101, and Q102. I was going to replace them anyway.
Will this change the out come of the requested reading?
If not the reading across C59 is +22.09vdc
That supply is floating with the output. Desoldering the rectifier ends of the red/black wires and connecting a load across the speaker terminals will make reading voltage and viewing signals simpler.
Without the rail voltage, do you have clean DC on the positive terminal of that capacitor?
- General Interest
- Car Audio
- Rockford 500BD old design
