Esentially nothing. 0.007v, jumps to 0.021v, then back to 0.007
Using ground as reference each side seperately has -9.67 vdc
Found the noise. U4 was defective with 9vdc on every pin. The amp produces audio now. Gotta replace the group of FET's associated with Q104 and then test thouroughly.
Still cant get the protect LED to light.
I will check this.When pin 7 is near 8v, the emitter of Q120 should be pulling one side of the LED high via R33.
It didnt show a short measuring in circuit, I swapped it out and now the LED lights as it should and the horrible on/off pop went away as well.
I'll get the FET's changed out, test, and update this post for others.
Thank you as always for all your help.
If they're properly soldered to the MEHSA strips, they should be about as good as the originals. The problem is... A lot of people don't get them soldered down with 100% coverage.
Side note... The transistor wasn't shorted. It was open, that's why you didn't read a short when testing it.
- General Interest
- Car Audio
- Rockford 1500bd (old design) PC-3417-D
