RJM 6DJ8 Phono
Hello,
I've been trying to decide on a phono stage project since March. I've looked into most of the projects here, and considered most of the available kits on the market.
I'm at the point now where I just want to build from a schematic; there are too many PCB projects and kits to choose from.
I have some JAN 6922's (that I'm guessing will work here), and this schematic looks to be about as basic as they come.
I did find this thread, and I don't think anyone ever made PCB's, or not. But, that's fine. Coming up with point-to-point a layout shouldn't be too difficult.
There's even a power supply to go with it.
I plan to go ahead and order some parts soon.
The Zout is too high.
It is better to use a stage CF at the output
I suggest ot use a stabilized ss HT voltage, the s/n ratio will be better.
In a phono stage I can't see any reason to use tube rectifier
If the Jan 6922 are Philips ECG they are very scarce as general quality. It is much better to use 6H23 russian
Walter
