Hi all
Just wondering if anyone might be able to help here.
I have a Soekris based DAC and I'm wanting to add an I2S ethernet /RJ45 connection so I can connect an Aqua LinQ streamer.
If you look at the attached
http://www.soekris.dk/download/dam1121/dam1121_manual.pdf
you will see details of the Soekris i2s input pin configuration.
In parallel, I also attach the LinQ's i2s output configuration here.
I have followed the LinQ pin output configuration and matched the input to the Soekris as per the manual. I used a generic RJ45 input module.
Unfortunately the audio stream from the LinQ is locking but the PCM stream is "garbage" e.g. random noise. Given I'm getting a lock, I can't work out the issue.
Any thoughts as to why the LinQ i2s stream isn't playing nicely with the Soekris?
Thanks and appreciation for any help you might be generous enough to provide 🙂
How do I do that?
The stream is heavily distorted but comes out of both channels.
It is odd as we are pretty sure we aligned the input and output connections so I wonder what the issue is.
You connect over the RXD/TXD pins shown on the schematic in the document you linked to.
More information towards the end of this guide. https://hifiduino.wordpress.com/2015/03/16/soekris-dam-1021-r-2r-dac-users-guide/
