Rigol DS2072A fully unlocked
I have a rigol ds2072a for sale, it is fully unlocked and is in essence a ds2302a, only difference in this ds2000 series is software related.
The original fan is replaced by a noctua fan with similar specs, but noise is much less, it was really annoying.
I think it's been used less than 100 hours.
No scratches, bumps or anything, like new
300 MHz analog bandwidth
Wider vertical range(500uV/div ~ 10V/div), lower noise floor, Better for small signal capturing
Max. sample rate 2G Sa/s
15Mpts standard memory depth or 56Mpts with option
Innovative "UltraVision" technology
Waveform capture rate up to 50,000 wfs/s
Up to 256 Levels intensity grading waveform display
Up to 65,000 frames Hardware based Real Time waveform, Record, Replay & Analysis functions (Std.)
Complete connectivities: USB Host& Device, LAN(LXI), Aux.
Asking for 470 euros.
EU only
Wanted to take a few photos of oscilloscope, in the system info it is actually registered as its bigger brother ds2302a,
Just shows the fact that the rigol series difference is software based.
