I'm planning on building an "upgrade" to a speaker design I built for a couple of friends. The configuration is a "3.5" way sealed design built around 2 Vifa P21WO2008 woofers (one acts as a "subwoofer" via an additional 2nd order lowpass filter). Given this "subwoofer" circuit, output near the lowpass filter corner is roughly that of a single woofer.
In the past, I've used a 3.5" Vifa mid and 3/4" Vifa dome tweeter, all split at 300/3000 Hz using a 3rd order passive network. I like the overall bass extension of these speakers, but would like a bit more detail in the midrange and high end. I'm considering using ribbon tweeters like the BG Neo3, Dayton ribbon tweeters or HiVi units.
Can anyone recommend a good ribbon tweeter for < $100 that could be used in a 3 way design. For that matter, what good midrange units are out there that would mate well with ribbon tweeters? I'd really like to increase detail and "openness." (Sorry, don't want to sound like Stereophile here).
Thanks...
Craig
Thanks...
Craig
I would recommend reading here:
http://www.zaphaudio.com/nondomes/
And:
http://www.zaphaudio.com/Givler1.html
Not sure about the woofer availability in that design however.
And:
I had some very good luck integrating a Fountek NeoCD3.0 into a vintage AR3a 3-way speaker. Stay away from the Arum Cantus ribbons sold by PE. I returned a pair because the tested so badly.
sdclc126 said:I would recommend reading here:
And:
Doesn't sound like this reviewer likes the sound of the various ribbon tweeters tested. I've never tried ribbon drivers, so I'm curious and have heard some good things about detail, etc. Any thoughts on this? Anyone here like the sound of ribbon tweeters over the standard dome tweeters?
speakerdoctor said:I had some very good luck integrating a Fountek NeoCD3.0 into a vintage AR3a 3-way speaker. Stay away from the Arum Cantus ribbons sold by PE. I returned a pair because the tested so badly.
mikela said:+1 on the Fountek NeoCD3.0.
Interesting that you both chose the FounTek unit. The reviewer at the link above seemed to like the BG Neo unit a little bit over the FounTek. But I'm all ears. It that's a superior driver, that would be perfect.
Thanks for the help!
cotdt said:make your own ribbon tweeter. would be cheaper that way
I'm all for DIY, but this seems a bit ambitious, esp. based on reading some rather elaborate (and very time consuming) forays into ribbon building described in the Ribbon/Planar/ESL section.
But, thanks for the suggestion!
The BG unit is not a true ribbon. true ribbons tend to measure poorly at lower frequencies, but they sound great.
craigwalsh said:Interesting that you both chose the FounTek unit. The reviewer at the link above seemed to like the BG Neo unit a little bit over the FounTek. But I'm all ears. It that's a superior driver, that would be perfect.
The newer Fountek's have metal face plates...unlike the one's Zaph tested.
When you say they measure poorly at lower frequencies, how low can they be crossed? I am looking at crossing around 3-5K.
How does the metal faceplate affect the response of these drivers?
The Fountek I used in the AR3a was crossed over at 5 kHz.
I believe I read somewhere that the earlier versions used plastic which resonated.
- Ribbon tweeter/mid suggestions
