Ribbed shaft potentiometers
I have some very nice knobs for ribbed shaft potentiometers. I just have no good potentiometers to go with them! All I ever get is either completely odd valued ribbed shaft ones (250K lin) or smooth shaft pots. Where in the world can I get some good ribbed shaft pots for volume regulation, like 50K log stereo?
Or is there a way to graft the ribbed shafts from broken pots onto the smooth shafters?
Hmmm.... I think you gave me an idea there! I'm going glue the ribbed shaft into a rubber hose, then glue the smooth shaft into the other side of the hose. I have some Old EFI fuel hoses around that should do the trick. After cleaning, though....
If the ribbed hole is bigger than the shaft I would use a piece of brass shim, like a sleeve around the shaft (available in auto body supply shops), if the shaft is bigger I would drill-out the knob. Either way you will need to install a set-screw to hold the knob to the shaft. E
