I'm thinking of building the reference RIAA design from page one of the datasheet for the LME49720.
I have the following filter parts available.
I don't see any problem with substituting the following filter instead, but I thought I'd ask the community.
Anyone think this op amp will have any issue with the slightly lower Z?
Thanks.
EDIT: C4 and R10 were in the original design I used with tubes, and I know they can be omitted.
Thanks.
As I said "Slightly lower Z"
The original was 27k, so yes. It's lower than the datasheets' suggested circuit.
NATIONAL did not have an issue with these values in their Application Note AN-1651.
View attachment NATIONAL_AN-1651.pdf
Good Luck!
I thought so. Thanks for the confirmation. This will be my first time building anything solid state 🙂
The response is better than I thought! Thanks PRR.
I love the passive RIAA, but one thing to be aware of is that peak signals, particularly on the outer grooves of a recording tend to be "hot". The illustration below is from a Shure whitepaper on trackability but illustrates how much energy you have to deal with.
So, don't skimp on the rail voltages if you want decent headroom.
LME49720 and LM4562 are (or were) identical devices. The max rail voltages in the datasheets for some reason are different.
Thanks for the tip. Headroom for peak signals is rarely a problem when using 300V and tubes 🙂 I was thinking +-12VDC for the op amp.
Split the gain as 30*30, it won't overload before the needle flies off the record. You could have rare 2V out of U1, so +/-5V is marginal, 12 ought to be ample.
Ok. Here's my preliminary design. I will power it from 2 9V batteries initially.
Out of curiosity, How would I transition this to a single ended power supply and a rail-to-rail output? I know the LME49720 won't work, but how about an AD823ANZ? I assume I just need input and output coupling caps?
Thanks.
Thanks.
You need to make C4 selectable. Some cartridges require no C at all: others up to 500pF. Shure is typical at 200pF. This is very important for correct response in the top octave, and is about loading the cartridge correctly, not about RIAA.
Also needed are: the U1 positive input DC biased to half the supply through a large resistor,
and large electrolytic capacitors (~470uF each) from R1 and R4 to ground.
Also needed are: U1 positive input DC biased to half the supply through a large resistor,
and large electrolytic capacitors from R1 and R4 to ground.
Single ended -- not a good idea for a passive.
I wouldn't do it, or recommend it, but that's how to do it with a single supply.
BTW, the input biasing for the second op amp comes from the output of the first op amp.
...I know the LME49720 won't work...
Why not???
No ordinary op-amp has a dedicated ground pin; that went out of style in 1963. All opamps can be run single-supply.
But you need more than in/out caps....
The 10pF represents the cable from the turntable to the amplifier. I should have said.
Why not???
Because from what I have read the rail to rail op amps can swing their output below ground.
"The AD823 is a dual precision, 16 MHz, JFET input op amp
that can operate from a single supply of 3.0 V to 36 V"
in any case, it was just an exercise. No real reason not to use dual voltages. Unless you wanted to run it from a single 9V 🙂
...from what I have read the rail to rail op amps can swing their output below ground....
At TA = 25°C, +VS = +5 V, RL = 2 kΩ to 2.5 V, unless otherwise noted.
OUTPUT CHARACTERISTICS
Output Voltage Swing
IL = ±100 μA - 0.025 to 4.975 V
IL = ±2 mA - 0.08 to 4.92 V
IL = ±10 mA - 0.25 to 4.75 V
Some milliVolts *above* ground/V-.
Ah:
"It has true single-supply capability with an input voltage range extending below ground in single-supply mode."
Do we know if the op has identifed the type of cartridge?
Such as a Moving Coil (MC) or Moving Magnet (MM) cartridge,
each with different requirement's I'm told?
I didn't see any mention of cartridge in the thread, that is why I ask.
Isn't it possible to taylor a design to a cartridge type and a specific
cartridge? Do we have to consider anything of the various cutting head
types when they made LPs and if there are any issues outstanding?
I assume that is device is only one LMC49720 using the "a" half
and the "b" half for one channel?
Cheers
Cheers
- Analogue Source
- RIAA passive filter values.
