Rhythmic Hum/Oscillation/Tube " flashing"
It also may happen that one amp is oscillating and the problem transfers to the other through common line impedance. Try one amp at a time to proof my theory.
Osvaldo, one amp usually starts the oscillation shortly after powering up (on its own no other equipment powered up). The other starts quietly and after 3-4 minutes it starts to oscillate. I will try your suggestion further and comment.
Reactions: Ervikingo
Peter, I agree with you and thus why I sent them back to the factory. To my ears, those amps are perfect as they come from the factory. No need to mess with them. Odd to say that on a diy forum.
All caps measured OK. I gave them a blank check to replace anything needed to bring them to full factory spec. They tested and said no changes were needed except a couple of tubes.
Speaking of tubes, I have swapped tubes between amps (no change) and also replaced the EL34 with new ones, no change.
If problem persists, what does the mfg say ?
This kinds of problem may occur when coupling between stages are unsufficiant i.e. when power surged in the
output stage loads the psu enough that voltage sinks, and this voltage drop reached a previous stage causing
even more power surge, a typical oscillator with a period defined by the storage caps.
Reactions: hbc and rayma
Have a look at the PSU in the link - I doubt that motorboating is caused by the PSU.
It's over-built like the rest of that mess.
The so-called designers were "parts-happy" - the more the better in their view.
I guess you are wrong. And we do not know if the actual amps corresponds to the schematics. Only a real
evaluation will show, nothing we can do on a forum.
Motorboating in general comes from interaction of the amp with psu according to my experience.
Motorboating often also comes from more than one time constants in the loop, especially if they are similar. Like the RC in the feedback loop and an RC like a coupling cap in the forward loop. Two similar TCs give a 2nd order loop which can build up enough phase shift to cause motorboating.
Really, without a schematic it's just trial and error.
I've anyway always operated on the idea that it is smarter to try to find a cause than throwing out random suggestions, so I'm out of here.
Wish you all good luck.
Jan
SPECIFICATIONS
Input Impedance RCA: 475 Kohm
Input Impedance XLR: 15 Kohm or 600 Ohm switchable
Input Sensitivity RCA: 750mV input = 110W output
Input Sensitivity XLR @ 15Kohms: 1.5 V input = 110W output
Input Sensitivity XLR @ 600 Ohms: 2.4 V input = 110W output (w/600 Ohm source)
Gain RCA: factory set for 31 dB; Range = 29.5 to 34.5dB
Gain XLR: factory set for 25 dB
Negative Feedback: factory set for 9dB of global NFB
Maximum Output Power into 5 Ohms: 110 Watts (1.5% THD @ 1kHz)
Maximum Output Power into 8 Ohms: 100 Watts (1.5% THD @ 1kHz)
Signal to Noise Ratio Ref. 1W: Typically 90 dB A-WGT 20-20K
Noise Floor: Typically 105μV = -77dBu A-WGT
Typically 388μV = -66dBu unweighted
Dynamic Range: 98dB
THD+noise @ 1W: less than 0.1%
Frequency Response at 110W full power: 15 Hz to 40 kHz FLAT
Frequency Response at 5W into 5 Ohms: 10 Hz to 65 kHz FLAT, -3dB @ 100KHz
Recommended Speaker Load: Optimized for 5 Ohms
Actual Output Impedance: 1.5 Ohms
Power Consumption (idle): 170 Watts (1.4A @120VAC)
Power Consumption (at Full Power 110W): 336 Watts (2.8A @120VAC)
Operating Mains Voltage: Factory set for 100V, 120V or 220-240VAC operation for original destination country's mains voltage.
Operating Mains Voltage: changeable with power transformer re-wiring and fuse value change.
Mains Voltage Frequency: 50~ 60Hz
Tube Complement (per each chassis):
Input Vacuum Tube: 1 x 12AX7 (front 9-pin tube)
Driver Vacuum Tube: 1x JAN NOS GE 7044 or 5687 (equivalent) (middle 9-pin tube)
Output Vacuum Tubes: 4 x Tungsol EL34B
B+ Voltage: 570V DC
Output Tube Quiescent Standing Current: 30mA
Set Bias for: 300mVDC measured across 10 Ohm cathode resistor
Lamp type: "FuseLamp" size 1/4" X 1 1/4", 12 volt, 0.15 amp; Units built after 5/2003 use white LEDs
Fuse values & types for SN#MSNP848 and below:
120VAC operation: MDL or MDA 4A / 250 Volt SLO-BLO size 1/4" X 1 1/4"
240VAC operation: MDL or MDA 2A / 250 Volt SLO-BLO size 1/4" X 1 1/4"
Fuse values & types for SN#MSNP849 and above:
120VAC = 5A/250V SLO-BLO, 5 x 20mm
240VAC = 3.15A/250V SLO-BLO, 5 x 20mm
B+ FUSE: MDA 1/2A Ceramic SLO-BLO size 1/4" x 1 1/4"
Dimensions: 15" deep x 13" wide x 8.75" tall
Shipping weight each: 45 pounds
Reactions: wg_ski
