• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Rhodium Plated RCA Jacks
Good question. Yes, and that is one of the advantages of these connectors. With more conventional RCA sockets, the ground is reliant upon the torque of the mounting hardware and the cleanliness of the solder lug. By using a body notch instead, a non-soldered interface is eliminated from the signal path.
A member recently posted a query about the mounting nut being positioned outside of the chassis. The external mounting nut is what makes the body notch possible, because during assembly, the connector body does not have to be passed through the mounting hole, which would be obstructed by the solder joint.
YHPM
Thank you for your praise. I'm considering having other audio connectors rhodium plated. The minimums are high, so I want to choose something popular. I noticed that while many eBay sellers offer rhodium plated banana plugs, none currently offer dual banana plugs with rhodium plating. Which of the below connectors do you think would be most popular?
(1) Rhodium-Plated Dual Banana Plugs
(2) Rhodium-Plated PC-Board Mount RCA Jacks
(3) Rhodium-Plated Chassis-Mount XLR Females
(4) Rhodium-Plated PC-Board Mount XLR Females
(5) Rhodium-Plated Chassis-Mount XLR Males
(6) Rhodium-Plated PC-Board Mount XLR Males
(7) Rhodium-Plated Chassis-Mount IEC Power Inlets
(8) Rhodium-Plated PC-Board-Mount IEC Power Inlets
I can have XLR connectors Rhodium plated on the contacts only, with projected male/female pricing being 3.99/4.99, or I can have all metal surfaces Rhodium plated, including the housings, bringing the expected male/female pricing to 6.99/9.99. Any thoughts as to which would be more sought?
Reduced International Shipping
Due to the significant cost increase of USPS Priority Mail International, the shipping for this eBay listing has been changed to USPS First Class Mail International, reducing the cost to about one-third of the former. USA shipments will still use USPS Priority Mail because domestic pricing has remained the same.
Rhodium Plated Teflon Insulated Air Tight RCA Jacks Chassis Socket Connectors | eBay
