RFI woes
So I added two 1nF caps in parallel and the RFI is 90% gone. I'm guessing the remaining might be sneaking in through my preamp. It's a huge improvement.
One question I still have is whether the cap should be connected to chassis or signal ground. My Dynaco uses several chassis connections so for ease/quickness of assembly, I just connected the cap to signal ground.
However, with my Aikido all-in-one I'm not sure what to do. Broskie's doc mentions combatting RFI with a 100pF to chassis ground. Currently my Aikido is connected to chassis ground but I'm thinking of playing with this to see if I can lower the little bit of buzz/hum I'm getting. So if I connect the Aikido PCB through a resistor to chassis, should RFI filter be connected through this same resistor or directly to the chassis? I guess it's not that hard to try both.
Thanks for everyone's help.
You might also try the trick I mentioned earlier of putting a cap between the incoming signal ground and the chassis. Normally there is enough inductance between the signal wiring internally and chassis (earth) to make the external interconnect cable screen look like a reasonable antenna at RF. At RF, your whole PCB is bouncing up and down, and this of course capacitively couples to the chassis and thus a lot of garbage to enters sensitive signal nodes. The other option is to use some comon mode ferrites, but a lot of people say they affect the sound (I cannot comment on this).
If you do this cap trick, then I'd use 100pf to 1nf (experiment) to chassis (mount as close as possible to your incoming connector) and then leave your 1nF cap you already fitted to signal ground, as you have already done.
Anyway, looks like you have made progress, so happy listening!
I've been dealing with RFI since moving into my house, perched on a hill with a view of a trio of transmission towers on an adjacent hill, 4700 feet away. I haven't been able to figure out for sure who broadcasts on them but there's definitely TV. However, the RFI I hear through the speaker is NPR on 94.9 FM.
Every piece of equipment I have, purchased or assembled has the issue except for my Panasonic XR-45 digital receiver.
Currently I'm using an ST-70 with Curcio CCDA driver and cap board connected to a scratch built grounded grid with a Squeezebox Touch and PS3 as sources.
I have about .6 VDC on my power line.
  • With the amp inputs shorted, I very faintly hear NPR from a foot or two away.
  • With a set of shielded interconnects shorted on one preamp end, NPR is louder, loud enough to clearly hear from my seating position.
  • With a set of unshielded interconnects, NPR is even louder.
I added 47pF ceramic bypass caps to the amp input with seemingly no effect.
If I unplug the amp from the wall, I can still hear NPR as the caps discharge so it doesn't seem to be RFI on the power line causing the problem.
What to try next?
Do you have the cage of the ST-70 installed and grounded to the chassis?
Cut 6" off and it's actually does worse in my rabbit ear test. However if I terminate it at my preamp it seems about the same as the others. To add insult to injury, when my grounded grid preamp's outputs unmute, I get more noise sounding like another radio station added to the mix.
You could try Canare Star Quad wire instead.
Another possibility, though daunting, is to convert your entire system to use balanced interconnects.
I added 100pF from signal to ground at my output RCAs of my Aikido all-in-one and that killed all traces of RFI. I opted not to use chassis ground because bypassing to signal ground worked. I didn't see the point of adding more wiring.
I'll now have to try the same trick on my grounded grid. I think I used 47pF on it.
The interconnect type now seems to be moot.
I might also remove the RC filter from the ST70 to see if it was the preamp all along. I'll see if mounting the cage has any effect. But everything is sounding good so I may save that for another day.
