I am planing on starting a community radio station and have all the licence end of things completely sussed...
I am however still researching into the best way to get the signal production and transmission side of things all up and running...
I have worked out the kits required for the stage (in order);
Audio Compression/Limiter
Stereo Encoder
PLL FM modulator
but now need to find a solution for a reasonably priced RF amplifier to boost the signal strength significantly...
I found a website where someone was using the Motorola MRF 150 FETs to produce a 600 watt HF solid state amplifier that they were using for HAM radio (http://www.k0gkd.com/ssamp.html)... The schematics they used were derived from a book written by the actual chip designer who worked for motorola...
What I was wondering is if anyone knew if these mosfet could be applied to the situation i speak of (specifically the amplification of a FM modulated signal)???
I know this question might be of n00b status compared to some of the absolute electronic knowledge based discussions posed by individuals on these forums but I really dont know where to turn otherwise...
ANY help would be GREATLY appreciated even if it is jsut being steered towards a different place where this kind of thing is discussed if this in not the place for this question to be posed...
Thanks guyz & Gals
Stereo Encoder
PLL FM modulator
Thanks guyz & Gals
Hi!
First question that comes to my mind is do you realy need 600W ??
MF150s are expensive devises but most have been used for making broadband amps upto 50mhz. They will work on FM band with only slight decrease in performance.
I suggest have a look at RF Parts VHF device inventory that should give a good idea.
To begin with I suggest start with something like 20-25 watts. One more option is buy an old VHF band pager unit or high power commercial VHF transmitter they all work around 138-174Mhz and should be easy to bring down in frew with slight modification.
FM amplifiers are biased for Class C operation so are many VHF amps for NBFM communication. Even if you get a linear amp for reasonable price it is simple to disconnect the bias.
Rahul
Rahul
I don't know about Australia but in the United States, we are required to use Government approved equipment for broadcasting.
That being said, I have built a number of FM amplifiers (I'll never admit why I have done this). I never got to the 600 watt power level but I did modify a 160 MHz, 500 watt amplifier to operate in the 88-108MHz band.
The most important thing is to make sure the "Q" of the tuned circuits are low enough so as to avoid amplitude changes when you deviate the carrier.
I wouldn't start with solid state output devices. They can be very difficult to make stable. Also, because of their low output impedance, harmonic filters can be difficult to design.
Try to find a high powered VHF amplifier and modify it for use on the FM band.
Hint: If the amplifier operates at about 160-170MHz, double the turns on the output inductors. That will get you very close to the FM band.
Good Luck!
Good Luck!
Yes i have looked into how to obtain the licence and that is easy and relatively cheap too (Community Radio is Noncommercial and licences are about $1200AU). However, I have not looked into the equipment requirements as to whether they need to be standard approved equipment of whether they could be homebrew equipment that needs to just need to meet minimum requirements for singal deviations/ranges/etc... Will look into this now lol
Check if your modulator/encoder are suitable for FM audio broadcasting, I mean if they contain 'pre-emphasis' filter.
Yes both the Audio Compressor/Limiter support pre-emphasis aswell as the Stereo Encoder and both are adjustable to either 50uS, 75uS or none...
Well yeah I kinda do need something with atleast this power as the area that I live in and intend to set it up in has terrain that will need something with a bit of "oomph", otherwise the signal will make it to about my front door
Thanks for the lead, I will look into this people and thank you for all your advice is has been really helpful
Frank Berry said:Try to find a high powered VHF amplifier and modify it for use on the FM band.
Thanks for the lead, I will looks into this people and would like to thank you for all your advice, is has been really helpful/insightful
oh btw
When I said "PLL FM modulator" i more so probably meant "PLL/Modulator/Freq. Generator" which was my understanding to basically be all in one circuit that generally flies under the flag "FM Exciter"....
Please correct me if i'm wrong here...
As far as I know PLL is FM de-modulator.
OK, I have looked into the technical specifications for broadcast services in Australia and short of saying OMG at the technical aspect of it
, I was unable to find anything that said that the equipment had to be of certain make or model or the like so at the moment there is still forward momentum...
They are very specific though on what they expect from your signal (p61-69 Apndx II - Tech Info) and here are some examples;
This basically summarises alot of what they expect but alot of these specifications come from the FM Exciter region rather than the actual RF amplifier... I can still see that the SNR is going to have to be pretty damn good. Even ensuring that things like a 4Hz (yes thats right 4Hz!) deviation of the 38kHz signal dont happen!!!
All i can see is even if one could get it all together it would be a nightmare trying to find someone with the technical equipment required to ensure that your signal met these specifications rather than the brodcasting authority being the first one to pull you up and give you some fine or somehing... Hmmm...
If anyone wants to offer any help in breaking any of this down a bit further and looking at apects of any part of the process than I would jump at some help lol... Any help with regards to RF amplification, especially if ideas could be coupled with some ideas on harmonic and band pass filtering that would help meet these outlined specifications would be a god send!!!
- The width of the radio frequency channel shall be 200 kHz.
- The channel spacing shall be 200 kHz with the lowest channel centre frequency being 87.7 MHz and the highest channel centre frequency being 107.9 MHz. A carrier frequency offset of ±100 kHz may be specified.
- Unless otherwise specified, the frequency of the unmodulated carrier shall be maintained within ±1000 Hz for a transmitter fed with a baseband signal or ±2000 Hz for a transmitter fed with a signal derived from another transmitter by frequency conversion
(i.e. not demodulation).
- The main carrier shall be centrally located in the channel and shall be frequency modulated by the baseband signal.
- The maximum frequency deviation of the main carrier (or the sub carrier for that matter) shall not exceed ±75 kHz.
- A positive value of the baseband signal (i.e. when the signal crosses the time axis with a positive slope) shall correspond to a positive frequency deviation of the main carrier.
- The frequency of the (suppressed) sub-carrier shall be 38,000 ±4 Hz.
- Pre-emphasis of the signal S shall be identical with that of the compatible signal M and shall be the same as that for monophonic transmission. The pre-emphasis characteristic of the audio signal shall be in accordance with the admittance/frequency characteristic of a parallel resistance-capacitance circuit having a time constant of 50 microseconds.
Hi!
Now since you have made it clear that 600W is must a broadband amplifier would not be suitable in my opinion. It is better to go in for tuned one. This would ensure a cleaner signal and better efficiency. Low pass filtering would be must to keep spurii down below the carrier. The filter would be air cored but would require a spectrum analyzer and some 10-20db tap for their proper alignment.
Modding a commercial equipment is still the easy way out.
If you wish to make your own I suggest first try out with cheaper Class C amp using APT MOSFET for industrial use , some app notes are there will look around.
One more aspect do give a thought to antenna system as you can get lot of gain , minimising on power. A 4-6 element colinear should give abt 10dbs ie with only 60W an ERP of 600W.
Rahul
Rahul
I'm sure Australia's broadcast laws are roughly similar to the US, Canada, and the UK.
Which means: while you CAN build-your-own, you have to "proof" it against ALL the regulations (you barely scratched the surface), and that really costs more than the transmitter. You don't build one transmitter; you build and proof one and then make dozens to spread the cost around. i.e. commercial gear.
Fer eggample: Transmitters have harmonic distortion just like audio amplifiers. Simple example: you transmit 600W on 90MHz, a Class-C amp with simple tuned circuit may transmit 5 or 10 watts on the second harmonic 180mHz. If aircraft, police, military, or other services are working on 180MHz, that leakage could wipe out their communications and make them very unhappy. You may be granted the right to be the dominant signal in your area at 90MHz, but no right to cause any interference on 180, 270, 360MHz, or the cross-modulation products that a sloppy transmitter can spew all over the RF spectrum. If you can prove rather strict out-of-band requirements, you have a leg to stand on if someone complains of OOB interference (you may still be asked to cooperate to mitigate the trouble).
If you are going to run even a Watt in the suburbs or 50 watts out in the desert, you NEED a Licensed Engineer. US FCC regulations have changed a LOT since I was a wee lad: we used to have to have a specific "Ticket" manning the transmitter any time it was on. It seems that advancing technology (more stable equipment that self-logs and will auto-shut-down at the slightest flaw) have reduced this to an annual check-up. Still, for initial set-up, you NEED a Broadcast Engineer to guide you through the maze, both regulations and practical details. I used to get the US broadcast magazines, and the classified ads were full of companies who did broadcast technical consultation.
Your best plan may be to buy a used transmitter. The transmitter companies are often the best source: they sell new stuff because it takes less oversight than the old stuff, and then they have to take the old stuff as trade-in. If you can work under a lesser level of technical oversight and logging than an urban broadcaster (if nobody is going to pitch a complaint when you broadcast 630 watts on a 600 watt license, as they do in the overcrowded city) an older transmitter may be just your thing. Or maybe not: if it is prone to fail once in a while, and you have to order expensive parts from far away, you may quickly pay more for repairs than a new transmitter. Another reason transmitters get retired is the new switching power supplies are more efficient than the old big-iron power supplies: the 1KW power bill will add-up over the years.
There must be broadcast engineers' forums around the Web. There may be one for Australian BEs. Or maybe not: there are only 272 commercial radio stations in the country (we must have almost that many in-range of the NYC area). You know there is funding (and surely support and advice, though probably massive bureaucracy) for Australian Community Broadcasting; see http://www.cbf.com.au/ and "Funds are available to help long term licensed community radio stations purchase necessary transmission equipment." More grants if you can claim Ethnic or Indigenous service.
I didn't say this, but: if you are really so "far out" that you need big power to reach a radio-starved audience, you might get away with a bootleg (unlicensed) operation. Get one of the Ramsey Kit "export" transmitters; they have more power than several of the radio stations in my area. You are still liable if you knock-out an aircraft radio at a critical moment, etc, so you didn't get this idea from me. Unless your police-state is better than ours, if you don't do any harm, the first legal step (assuming anybody notices) would be a "DESIST!" order. When you go off the air, you will find out how much your audience loves you, and can leverage their outrage into a more legal setup.
Yes, but not like that.
The plan shown is a single-sideband "linear" amplifier. In audio terms, it is a class AB amplifier biased for an idle current of about 3% of the maximum peak current (pretty darn "B" by tube-audio standards, though transistor folks would call it "AB"). Its output is proportional to its input. That works for AM or for SSB, though AM is so inefficient that you almost never bother with "linear" amplifiers.
It would work for FM but it isn't right. In FM you do NOT want your output power to vary at all. So all this tricky bias stuff is pointless. And this amp is not made to run full-power 100% of the time, it taps full power only on speech peaks. For FM work you would want to bias and drive into class C: hard-off when drive fails, and always driven hard-saturated for maximum efficiency. Total fuzz-box. That leads to more re-optimizations than I can think of.
And his filtering scheme may be legal for amateur radio, which has considerable leeway for experimental gear, but may be unacceptable for the broadcast bands.
If I am reading it right, he only built for up to the 10 meter band, which is around 30mHz, far below your ~100MHz. Yes, the citation implies up to 150mHz, but working the last octave of a device's "potential" is usually a job for Experts.
For short-range over hilly country, consider 1MHz (AM band) instead of 100MHZ (FM band). A typical hill is "small" compared to a 600KHz wave, the wave just slides over the top and into the valley like treacle. But a hill is "large" compared to a 100MHz wave, a perfect obstacle, you are just warming outer space and not getting any power to the far side of the hill.
Do not confuse the short-range case with the more familiar situation of driving 100 miles of of the city into the hills, and AM going in and out. AM "skips" off the ionosphere and at 100 miles you will get both the ground-wave and a sky-wave, generally out of phase but similar amplitude. Small variations in either one can reach a near-perfect null, or worse the imperfect nulling of one sideband more than the other. AM over a distance in hills is bad; short-range AM tends to flood hills well.
OTOH, an efficient AM-band antenna is a quarter-mile tall and a Major Investment. You can comprimise the size but at the cost of power required. OTOOH, if most of your audience is in one direction, and you can erect telephone poles over a large field, a Rhombic antenna 1,000 feet long and 50 feet off the ground can throw a lot of 1mHz horizontally. (That's basically how the US Navy throws so much 20KHz power that it can crisscross the world and penetrate several feet underwater, to reach hidden submarines. Their exact size is IIRC secret, but a couple miles of wire on towers and a few megawatts does the trick. Scaling-down, 500 watts should throw hundreds of miles.)
What you speak of falls under this category;
I may not be an engineer of any sorts but have a good science foundation and understand the principles of frequencies and things like high, low and band pass filter and the diference b/w them and the likes of 1st, 2nd and 3rd order harmonics. I never intended in not including a harmonic filter after RF amplification... I have been researching harmonic filters and their inherent properties trying to determine what models/designs are best for this application... From what i've seen these can be purchased prefabricated and tested new or near new over the internet also with good attenuation being seen in the order of 80 dB in the 2nd order and even more in 3rd and 4th order....
The flow chart of the setup I envisioned comprised of (in order);
Out-of-band and spurious emissions
9. The necessary bandwidth of the radio frequency emission is deemed to extend 120 kHz from the carrier frequency.
10. Any emission on a frequency removed from the carrier by more than 120 kHz, and up to and including 240 kHz, shall be attenuated at least 25 dB below the level of the unmodulated carrier. Any emission on a frequency removed from the carrier by more than 240 kHz, and up to and including 600 kHz, shall be attenuated at least 35 dB below the level of the unmodulated carrier. Any emission on a frequency removed from the carrier by more than 600 kHz shall be attenuated at least 43 + 10log P dB (where P is transmitter power in watts) below the level of the unmodulated carrier, or 80 dB, whichever is the lesser attenuation.
- Sound Sources (Mics, Computer, Decks, etc.)
- Mixer
- Audio Compressor/Limiter
- Stereo Encoder
- FM Exciter (Oscillator/Buffer)
- RF Amplifier
- Harmonic Filter
- Regulatory specified polarity antenna
[/list=1]
The equipment chosen for 2x audio compressors/limiter, stereo encoder and FM exciter should be of quality enough to meet most of the guidelines that a more specifically related to the signal except for what has been stated above which relies primarily one harmonic filtering...
The main purpose of my discussion here was to try and determine whether RF amplification was possible by the electronics hobbist to a degree where it could be used on a commercial level...
In most cases, "Power" is determined by ERP - Effective Radiated Power. Which is a measurement at distances away from the antenna in uvolts...
In practice, the thing that will make ur "community" radio station heard is the "HAAT" of the antenna. Height Above Average Terrain. In other words, an antenna on top of a 1,000ft tower or on a mountain top above the area to be served is better than a 100,000watt transmitter with an antenna in a basement (just to make the point clear).
So, the 600watt limit may or may not be linked to ERP where you are concerned. Find out.
Finding a ~600watt transmitter or amplfier for FM service is pretty easy on the broadcast market these days. New or used. You'd be better off with a TUBE unit than a solid state unit. You can fix the TUBE unit, you probably can not fix the solid state unit (given that you have no idea about this stuff at all). On the other hand, the TUBE unit can KILL YOU DEAD - so you might want to factor that in as well.
I'd try to find qualified people on the internet that happen to be in your area, or just qualified RF people somewhere within TRAVELING DISTANCE of your area and see what you can learn, or get them to do for you...
You might be able to attract an RF savy person who is willing to work for/with you for the fun of it, or for the promise of some later payment (assuming you will be selling ads on your station).
Also, look around for Ham Radio operators, they often know quite a bit about RF issues and where to buy things cheap!
There are many issues to deal with - but the best thing is to get something legal and on the air, no matter what the power level is... and get started!!
In practice, IF there are no commercial stations in your area you will not have to deal with many regs (at least at first). If there are commercial stations in the area - AFTER you have a license - call on their chief engineers for help. You may find that they will donate all sorts of "obsolete" gear that is just fine for your station!
Do that in the bigger towns or cities via the phone and letter, email and you may find yourself under a flood of gear!
_-_-bear
PS. you probably can NOT build your own transmitter, exciter or amplifier under your Regs - you have to determine what your regulating body's regs say about that in specific. Usually they have to meet specific emissions standards and those have to be proven and warranteed, usually via the manufacturer - otherwise you will likely have to go through a similar acceptance/approval process. Which may be possible, depending on what your regs say. I'd ask the regulating body that issued your license what they require and for citation of the specific regulation so you can read it for yourself (the person you speak to may or may not really know what the law/regs say)....
_-_-bear
I can not imagine your equivalent of our FCC letting you build your own transmitter, or carrier source. It must be tuned, must have certified emission specs, and the cost of doing it for only one is absurd. Just because it is community radio does not mean that it can be ham radio (or lower) quality.
The suggestion of finding a semi-competent broadcast engineer should be heeded. He could undoubtedly steer you in the right direction on what type of used gear to get or stay clear off. He may even be able to convince you that you may not really need 600W, but a decent antenna. May depend what is cheaper to locate and install. A tall tower may not be. He should know. If not, find another one who does.
Jocko
Jocko
Quite right. HAMs also are a friendly lot. 'Help All Mankind'. I can vouch cause I am one.
My call VU3WJM just do a Google.
I do not know the cause for this misconception but HAM radio requirements are quite stringent. The units must cope and dig in for 5W signal across the globe while coping with the KW across the block. Atlas radio has been a hero on many expeditions. ISS also has a HAM station on board that is presently switched on.
Unfortunately not much HAM radio gear would be useful for community radio but HAMs themselves can be. Ramsey kits are good way to go you can start with a low power and later use the same a driver.
Rahul
mmm?
I have built a few FM transmitters installed here in NZ....they are not legal ones but could be. After lots of mucking about I found that using a standard AM radio telephone was the best starting point since they already have the approval and good output specs. Simply remove the front end oscillator section and replace it with a varicap diode tuned crystal of about 9-12 times less than your output frequency. You can get to 12 times with 3 multiplier stages and get the 75khz deviation needed for broadcast FM. In NZ and AUS, the top part of the FM band was used for AM radio telephones in the past and so there are plenty of 88-108Mhz units that have been junked. (Tait, Plessy, Pye, Philips)The 600watt output seems to me way too high. If you really want this sort of power; then buy a linear power amp 20W-600 and then fit good filters into the antenna circuit. Cavity tuned circuits are ideal for this task and there will be plenty of surplus in AUS and NZ after the repeater sites closed out off this band.
In NZ and AUS your equipment must meet the specs but you will not be procecuted providing you don't interfere with other services. If you do interfere then your equipment can be confiscated and you could be fined up to $200!.
Good luck with your project
- RF amplifier
