Amp is T1000-4
Amp has rail voltage but no regulated voltage.Across pin 4/8 of the op-amp i see 3 ohms.From the output of the positive regulator to output of negative regulator i see 24 ohms.Do i have a shorted op amp or the is some other components i could check?
Desolder pin 4 and 8 of each IC until the short goes away.Easier with TH but doable with SMD
Sent from my HTC Desire 626 using Tapatalk
It will be very difficult to do.This amp has more than one vertical crossover board with op-amps.
Any other way to spot a shorted op-amp
Temperature can be an indicator. Freeze all of the components with component cooler or an inverted can of canned air. Let the white condensate//frost form on the components and then switch on power. If one op-amp defrosts much quicker than the others, it could be defective.
Perry’s idea is a good one and I would try it first
However this may be an alternative, How hard would it be to desolder one vertical board at a time? This may be a way to narrow done the defective component to one board and once the board is isolated and removed from main board,apply the technique I recommended in previous post.
I'm not familiar with the layout of this amp and most Kicker amps have the x-over on a separate plug in board. Although, I've had to go through multiple op-amp chips to find a failed chip.Tedious and time consuming but with a little patient and care can be done.
